Mind vs mirage
tuomoruutufan
Mind vs mirage
Post by tuomoruutufan »
I can hit mirage perfectly after a trick ie. Leg over - mirage or atw-mirage but if you asked me to hit mirage and mirage only i screw up.
Anybody else have a similar problem.
Im sure the awnser is simply more practice but i was just wonderin if this is common
~Shawn Patrick Boyle~
zachatree
Happy Hippy Hoffa
Post by zachatree »
every one has there own problems. i think at one point i had the opposite problem as what u have, i couldnt hit the tricks after other tricks but i could hit them solo. if u ask me its kinda cool that u can hit them in strings but the awsner to fixing your problem is what u have already said. PRACTICE and drill.
BainbridgeShred
Post by BainbridgeShred »
Make sure your setting the bag straight up, a little under waste high. What you might be doing is when you hit mirage out of a trick, you body is better posistioned to give a clean set, whereas when trying mirage before a string, your body goofs on you.
Post by CIC flurry »
It sounds similar to when some people wanna do a big toe move, and toe stall a few times before hand to get a rhtyhm, as opposed to starting from a dead stop.
Holla,
Tom
CIC
tuomoruutufan
hey tom since you posted about it you actually do that. you always start with a few toe stalls then go into your string. i wonder if that would help me.
itsanother
Post by itsanother »
i think you shoudl just practice the mirage a little more...actually just more. and at some point your mirages will be easy enough to put into a string.
for example when i first started cippers i could only do them if i hit the bag with the inside of my foot. NOW i can do a clipper from any trick. its all about being "fluent" with the trick
TIM SHAN
Blackend
Post by Blackend »
I say...do it again! Keep doing it until you get it down. It took me about two weeks of footbagging to finally learn mirage and a while longer to get it down so it looks cool (even though I still drop it 8O) Don't forget to drill on your flip. I suck at coaching others in writing, so I'm not even going to try. I'm just going to tell you to keep doing it until you do it right. :)
Sam Mayer
"Son, a woman is like a beer. They smell good, they look good, you'd step over your own mother just to get one!" - Homer Simpson
Shredster
Post by Shredster »
I actually have a problem with ps whirls.
If I hit a butterfly or something first, almost no prob. Set from my hand to clipper > ps whirl, PSH, i'll be lucky
Its all in how well you have the move down I guess.
Chris May
