problem with clipper set
CheeseMan
Post by CheeseMan »
i can get the clipper stall, but when i set the bag back up, it comes up and hits the side of my body or my chest. i need some advice so that i can get the clipper straight up. thx
Paolo Arce - HOY!
Do (not) read text in parentheses.
sniikeri
Lauri Jii
Post by sniikeri »
There is no other way than hard practice. Unfortunately.
With time you'll find the right technique.
Remember to skool 'em both sides! I really mean it. Though it may be hard to do it flipside first, still practice them.
At the end you're name will be Anssi "BeeSauce" Sundberg.
Lauri Jaakkola
buddystarr
Post by buddystarr »
i am also having trouble after i stall the bag. by the way, with the mirage, am i supposed to return the leg that dexes to the ground before i catch it?
fullchromelogic
same with me
Post by fullchromelogic »
the bag usually hits me in the hip. but if i play with a sandman, or an extremely broken in 32-pannel, it seems to go where it should. im also having some trouble doing clipper to clipper.
Cormac Gartland
BEAcon FOOtbag COAlition
Post by Senor Grommet »
make sure to lean over your clipper
practice w/o the bag, a motion of bringing your clipper foot down, then straight up slowly, concentrating on maintaining the crank of your ankle and your balance.
the reason the bag hits you when you try to set the clipper is because the clipper foot is literally pulling the bag towards your body before that foot lets the bag go. Practice letting the bag go straight up.
Chema
Location: Footn'Bag (Boise), Idaho, USA, Earth, Frappr Map
Post by Chema »
buddystarr wrote:i am also having trouble after i stall the bag. by the way, with the mirage, am i supposed to return the leg that dexes to the ground before i catch it?
For the Clipper try doing it quickly instead of holding the stall try and just do a quick delay (you may already do this, but it can help with the motion of sending it up)
For the Mirage yes definately try and get that dex foot down ASAP, try to not even do a whole dex just kinda step over it quickly.
Chema CB
