move name
Xain
move name
Post by Xain »
I can't find the name of this move anywhere
zoid> paradox symp mirage
and that would be 5 adds right?
yeah I think that would be the correct name - zoid set ps mirage. Lots of moves don't have move names beyond the technical name because some people think it's silly to name every move - especially moves that are just set off a different surface - like cloud kick whirl or something.
I'm not sure if you get an add for zoid set or not - I would think that it would go to the previous move - usually adds only count for what is done after the bag leaves the foot. However it's still a cool move - I'm pretty sure it would have been hit before but sounds fun none the less.
max
Australofrenchbrityorkus
Post by max »
it's a 4 add. setting from zoid is considered the same as setting from clip (i.e it's xbod, so you can get a pdx add):
zoid > (no plant while) same in [bod][dex][pdx] > op toe [del]
Maxime Boucoiran
French ConneXion
BFC
Commodore
Post by Commodore »
What is this trick called set clip> op in> op toe?
SandWraith
Post by SandWraith »
clipper set mirage
blog
Commodore
Post by Commodore »
:lol: Why didn't I think of that. Ok what's this move set toe> same out> op in> same clip? The clip in the end is like refraction.
