Fusion - 5 adds or 6
What is the add value of Fusion
5
10
50%
6
9
45%
Something else
1
5%
Total votes: 20
Post by Senor Grommet »
what tricks would receive x dex under the system by which you operate Jeremy?
hacksterbator
Washed-Up Child Star
Post by hacksterbator »
jer: i agree with part of your thought on this, yeah fusion doesn't have the same difficulty as other sixs, but i don't see why this wouldn't count for x-dex. why shouldn't the double down be broken into a full dex and a half dex? it makes more sense to do that then to say it doesn't get the x-dex because it's even more than a full dex. same with fury, break it down into a full dex, a half dex, and an other full dex. or nemisis even; full dex, half dex, full dex, half dex. nemesis definatly is one of the hardest 6's around. why shouldn't it be a seven (since we're using the add system as a way of determining difficulty [which of course doesn't always work]).
A.G.
ShredStylez
Republican
Post by ShredStylez »
yea ted i agree. i too respect ur mom alot more then the other typical 7's. i also agree with jeremy.
i have changed my stance. if the dexes r done cleanly give fusion 6.
There is always a bigger trick.
Go watch a vid. of Dylan Fry.
-Mark "The Force" Schwartz
Moves that would get an x dex under the "you can't split the dexes up" theory
Atomsmasher
Reactor
Sumo
shooting mirage
tunguska
toe blur
blurry blur
there are obviously others.
The reason why I don't think you should split up the dexes is because it's just one action - you do one movement, which dexes the bag twice. If I saw someone do an omlette bailed to a ss butterfly - two distinct dexing actions on the one foot, then that move should get an x dex.
hacksterbator
humm, i agree with the omlette bailed ss butterfly, since there are 2 very obvious dexes in there, but i think that since in one action you do more than one dex, it should qualify for x-dex... there's too much theory in footbag... let's just shred! :D
A.G.
