Filler Discussion / Online Filler Sources
I've been having some trouble with my footbags, they die too quickly. Right now, I'm using very heavy, very big zinc plated BBs, plastic hacky sack pellets (a bit lumpy and pokey, maybe they're the problem) and scraps of facile to make my filler.
I want to avoid using lead (although I love how it plays), so I guess I want tiny little steel shot. Also, I bought some different plastic hacky sack pellets, the softer, smaller, rounder ones, so I'm hoping those will be a little less abbrasive. I believe I'll also continue to add scraps of facile for soft squishiness in the filler, plus other soft filler elements inspired by some ideas my friends had...
Anyone have thoughts on filler (either what I've suggested, or their own)?
Anyone know where I can order a good kind of steel shot online?
hackeysnacker
here are my ideas, i think that the hacky-ack pellets should be switched out to a less abrasive filelr, maybe like the ones seen in abshire bags, that i think can be obtained at michael's, also seed beads are my preferential type of filler instead of plastic bigger pellets, and the ones im using now dont seem to break apart, also as a suggestion, i think that steel shot is too light for my taste, because i like heavy, dense fillers, so why not provide lead shot primarily, and if your customer would prefer another kind, simply use steel shot? i think that the footbag's preformance comes first, and i like the variation of fillers that sitchers use...
Griffin O'HaraWasabi wrote:I thought they were skins of animals hit by a nuclear holocaust that were made into cute little shred bags.
Kyle Hewitt
- something more funny
Re: Filler Discussion / Online Filler Sources
Matt Cross wrote:I've been having some trouble with my footbags, they die too quickly.
Hmmmm, when I looked at the filler in Zebs bag there were 3 types of filler I think and there was one that was chipping and falling apart and causeing sharp things to float around in the bag
crazylegs32
Hey man, I was just fucking around. I pick it up at an ammo store 15 minutes from my house. I thought I was being fairly fucking generous when I said I would hook up anyone who needed it.david wrote:That's really mature, and I'm sure its the exact attitude you would like to have directed to you when you ask a question to improve the product you make.TheVindicator wrote:It doesn't matter where or how
All that matters is I have it
Thanks for clearing that up, now, back to the topic... does anyone here have any experience with both lead shot and steel shot? I haven't used lead, but I've used steel (they're just too big currently) and I didn't have to fill the bag up too much to get it up to the right weight. I think the steel could work out just fine.
- shredzilla
I have experience with both. They're both great fills. The lead's obviously softer, and there's the common theory that it coats the bag as well as the plastic beads you're using. Steel seems to do a similar thing, but not nearly as much. I'm only using steel because of people's lead-phobia, otherwise I probably would've stuck with lead.
www.ballisticproducts.com is another site, and I think their stuff is a tad cheaper.
