Arthroscopy
@ndrew
Arthroscopy
Post by @ndrew »
Hello. About 7 months ago while I was doing barfly for the first time I injured my knee. Nobody knew what happend to me. I went to 5 doctors. They all were saying different things. Finally, I went to the hospital. I had arthroscopy and it turned out that my lateral meniscus is broken so they had to cut out part of it. I also have wasted articular cartilage. Did anybody had same thing?? Did you could play footbag again??
gangsta
Post by gangsta »
How was the form on that Barfly? What went wrong? I'd like to avoid doing the same thing...
@ndrew
Post by @ndrew »
nothing was wrong, barfly was perfectly clean
HooD
HoodluM
Post by HooD »
Andada,
Cartilage tears and ligament tears are complicated things. There are a lot of factors that play into how well you will recover. For the Cartilage (meniscus) tear, a couple factors are : Location of the tear & severity of the tear. Not all of the meniscus is vascular (supplied with blood) so that means not all of the meniscus heals the same. Hopefully your tear won't require surgery and if it does, you'd probably already know because they did an arthroscopy to see what was going on. Again, there are a couple factors that play into the lateral ligament, but for the most part you should be able to play again.
What type of rehab have you been doing ? Any type of bracing to take lateral pressure off your knee ? Hopefully you'll get a full recovery and if not you'll have to modify your game or not play at all if it doesn't recover well. Most younger patients tend to recover pretty well. Goodluck.
More C4 please <3
@ndrew
Post by @ndrew »
doctor said that I should do a lot of swimming and ride on the bike once a week
janis
Post by janis »
I had a meniscus injury a while back, though it doesn't sound as serious as yours. Swimming is really good exercise for your recovery
smokefree
Post by smokefree »
can you still play footbag at the moment?
Anthony
MONKEY CLAW!
@ndrew
Post by @ndrew »
No, I can`t, maybe in april I would be able to play
