Hello modified! This is my first topic
This is a tutorial about how to shorten your lace ends or just to tie them firmly
This works with Footbag Lacing method 3
1. Tie your shoe as you normally would
2. Put your lace loops under the big loops
3. Put the loose lace ends inside the loops...
...and tie them with Reef Knot
Here you go and have fun. Peace!
Peace man!
Started playing in spring 2009
I just do a train-track lacing until I come to a point where I have to make the loops to prop up the toe walls. Then I tie off.
I usually find problems in having too little to lace with than having too much.
I ran into the problem with long laces years ago with my second pair of Chuck Taylors (converse).
I somehow resolved to tieing the laces around my ankle and back to tie off right above the tongue. I've been doing this daily now for years and Lavers turned out to be no exception.
As long as you pull your toes toward your shin when you are wrapping around your ankle, when you relax it wont be to tight.
I see no restrictions in movement and it actually does the best job at keeping the tongue of the shoe down.
I'm probably the only one who does this, but I assure you it works for me.
~Donovon
Matt Cross wrote:one could also consider trimming them to a shorter length with scissors and then burning the tips with a lighter, so they don't fray.
Right! Which they are in the photo.
First thing I thought reading the thread title.... burn the ends. Then I see the first photo and think, "Is he gonna cut them even shorter and re-burn them?"
I have done the above in the past and found that it helps keep the laces tight while you play as well.
