Dirty
Dirty
I've realised that there are lots of different ways of making tricks look bad.
You can "the" dexes.
You can slur dexes.
You can do semi frigid osis sets instead of properly spinning (releasing the bag half way into the spin)
You can spin on moves when you shouldn't (dlo and symp mirage)
You can drag osis' - stall before you have the foot in a crossbody position and not spinning enough.
You can "duck" when the bag is well over head height.
The bag can hit you in the middle of a move when you don't want it to.
It gets confusing trying to know what you should call all these things. For example is a dlo where you spin slurry? the? does it have another name? I can't be bothered with all the different names. If something doesn't look clean I'm going to call it dirty - just thought I'd let people know so if you notice me calling moves that, you'll know what I mean.
comastalker
Post by comastalker »
yep, but I always thought "the" IS "dirty" ?!
You aren't just able to "the" dexes, a "the" dex is a "thin" dex.
I know (like "thin") there are too many names (remember this tor-idea),
but I always thought dirty movements are generally called "the"
-Richard Vock-
"And today the great Yertle, The Marvelous he,
Is King of the Mud. That is all he can see.
And the turtles, of course...all turtles are free
As turtles and, maybe, all creatures should be."
- Dr. Seuss
FlexThis
Post by FlexThis »
KronoKicker
Post by KronoKicker »
if you turn too much on a symposium mirage, does it become more like a x-body rake. Or is it just a "the" symposium mirage?
Aric McIntosh
*Jethro*
Post by *Jethro* »
what is it called when you do a "sunil" kind of dex e.g.when you put your toe outwards before you catch the bag??Is it still counted as a full dex?because its kind of like the bag is dexing for you and just falling into the dex instead of actually bringing your foot around the bag.
Hopefully back one day.
Jesse Malouf
cheebs
Post by cheebs »
If you turn when u do a symposium mirage it doesnt mean its them, it becomes a x-bod rake.
Chris Kovacs
The Ministry of Silly walks
http://www.JerseyShred.com
SlashC
Post by SlashC »
I don't use "the" or "dirty". My friend and I use the word flim...
Rory "Tophat" Dawson
I disagree. That's like saying that a the parradon is a butterfly (and acceptable).
When you spin on a dlo or a symp mirage or a xbody rake, it looks ugly and it isn't clean. That's why I'm calling it dirty.
It's good that x body rake was brought up. Cross Body Rake is a rake where the stall is in the cross body position. When you spin on the move it means that you are stalling behind you, not cross body at all. So it isn't clean - it's dirty.
I think there is nothing wrong with Sunil's eggbeater dexes. They are clean as far as I'm concerned. There is a difference between style/technique and not doing a move properly.
*Jethro*
Post by *Jethro* »
but Sunil dexes like that on almost all his moves that end in toe,not just his eggbeaters.
Jesse Malouf
Well personally I don't have any problems with his dexes and if I could hit stepping ducking pdx eggbeater the way he does, I would.
HackyRichard
Post by HackyRichard »
you need to be able to hit eggbeaters first jeremy :p
14 days till Montreal
Richard Pearce
FlexThis
Post by FlexThis »
Post by Muffinman »
The, sloppy, slurry, iffy, weak: they all mean the same as "dirty" to me.
As for the inward-ankle-turned eggbeater (and other) dexes, I agree that they aren't as clean as a "regular" eggbeater dex.
shreddaily
Post by shreddaily »
The problem is all of the things Jeremy has listed have a different OFFENSE value. personaly seeing a the paradon offends me more than a pulled osis, but I generaly don't call things the untill I know the player and their style better.
Its kind of rude to step into a circle and start calling things "dirty" and even calling something the can offend someone if you're not careful.
I use the term THIN alot, dirty sounds pretty personal to me. Either way... people should know they can do something better, or cleaner, but advise is always better than critisism.
....(steps off soapbox and watches some cartoons)
sPinko-Mania
Post by sPinko-Mania »
If I'm going to call people on something, I'll just identify it specifically. Instead of saying that was a 'dirty' duck, I'll just say that it was too high, or the if it didn't pass over the head/neck area. Or if someone is symp. miraging and actually raking it, I'll just say that. I have no problem with not having a word for this problem, although I see what you're saying, there are a crapload of ways you can mess up moves. 'Bad/poor form' seems like a good phrase for problems a lot of the time, because you can apply it to a move which is technically fine but just has poor style (stepping on a pdx mirage or infinity), as well as technically bad things (like a slurred stepping set).
Also I don't think there is anything wrong with Sunil's style in legovers. Here we call that technique 'the Sunil legover' and it just makes it a bit easier on yourself. It generally leads to a better tighter dex, even if the dex is 'smaller', if y'know what I mean. Whether or not it looks good is another issue.
Ben Spink McCarthy
They say God lives inside us. If this is true, I hope he likes salmonella. Because that's what he's getting.
comastalker
I still think dirty equals the
-Richard Vock-
- Dr. Seuss
ericksonj
Post by ericksonj »
I personally think there are so many different footbag related words that it is hard to keep them all straight. The more people you end up shredding with, the more terms you hear. Nate and I either say 'The' or 'thin', or "that wasn't clean." But they all mean the same thing. It just brings to the attention of the other person that the move could have been executed better. I would use these terms sparingly though when you are not in a training session. There is nothing worse than shredding in public with a bunch of spectators watching and having your partner shout out that one of your moves was unclean. Its all about the fun on those days... Training days are when the biznass gets done.
Always Shreddin
James Erickson
ShredPirate
Punkass
Post by ShredPirate »
i think there only needs to be 2 terms:
a term for unclean dex's (the)
and a term for unclean concepts (slurry, scoopy osis, rakey symps, turning toe moves, super high ducks/spins)
the term 'the' can be like a code red offense, and the others can be code yellow.
Chris Pinkus
comastalker
code red offense ?! that's funny.
-Richard Vock-
- Dr. Seuss
ptaku
Post by ptaku »
Maybe just 'unclean' 'not clean'? And then say when was move unclean and what part of a move was unclean. That would be simple. I don't see any reason to complicate it.
Pawel Ptaszynski
NAS
Be strong, LIVESTRONG
http://www.laf.org
http://www.wearyellow.com
