Forward or Reverse Swirls ?
Just a simple poll about which way you perform your swirls strongest, forward or reverse ?
I've been doing reverse swirls quite strong for a while now, but I'm going to add foward swirls in more, I find it so much easier to do my reverse swirl motion. I don't ever think I could do a reverse swirl set, a swirl set is very reasonable.
More C4 please <3
wow exactly the same experience as johnny, and forward is better in some ways cause its much easier to do at the end of multi dex tricks
Jon's FootBlog
MSN: [email protected]
- full nelson
- 8-Bit Ninja
Are you trying to say that every swirl trick at footbag.org is wrong and I've been confused about swirls forever? I note that Ellis Piltz is also wrong - because he continues to label videos of people hitting swirls the wrong way round.
To clarify - a swirl where you bring your foot behind the bag, over it, back down infront of it and then stall it is usually in my experience called a swirl and if someone performs a lets say a butterfly version of this it's written something like this - clip>same in>op swirl (back)>same clip
A swirl where you bring your foot infront of the bag, up over it, down behind it and under it to stall is in my experience called a reverse swirl and a butterfly version of it is usually written like this: clip>same in>op swirl (front)>same clip.
Freestly notation has always been about the direction the foot goes in to begin with - hence an "in dexterity" is always one where you bring your foot inwards first and then outwards. A back swirl is a swirl where you start by going backwards (relative to the direction you are facing and the bag) while a reverse/frontwards/forwards swirl is one where you begin by moving the dexing leg infront of the bag - the first action is forwards!!
- shreddaily
- Flower Child
- full nelson
- 8-Bit Ninja
Ah, I see what you mean. It's just a misunderstanding in description. You're technically right. Everyone knows the difference between a swirl and reverse. We've always called it the other way because we generally saw the dexterity in a swirl being forward. You had to go and bring jobs into it
This is the first time I've even looked at jobs for swirl.
Brad
I used to just have swirls on one side really easy, and far butterfly (symple) swirls both sides. Now I don't really have swirls very well on either side, but I still have the symple ones, and I also have rev swirls and a bunch of rev swirling moves both sides. Which is weird... i guess I should work on getting my swirls back.
- King Monkey
i cant see how anyone finds reverse swirling easier||!
regular swirl is much better for me, i cant seem to get the speed to reverse swirl.. or my knee pops when i do it for some reason
hi there just to add my drop... i counted for reverse,those who s seen me play know why..
i think i came up with the word :revstein:- i was probably not the first one to hit it but i was waiting for other with that trick on the video and nobody replied so i named it revstein-after reverse ripstein..
regural ripsteins are much harder for me..the motion feels better but the final execution is one of my recent issues...
i ll try to videotape some attempts.. cannt wait to step into the shred circle again....
respect Peter Brocka
Slovak republic
Slovak republic
..do your best and fuck the rest..
JUDr. Peter BroÄ
JUDr. Peter BroÄ
