"Meantime"
Blue_turnip
"Meantime"
Post by Blue_turnip »
Hi,
Im almost certain there is a name for this, but none the less, I took the liberty of introducing my simple concept to Melbourne footbaggers and Singaporean footbaggers. You say "there is lots of 'meantime'" when the main components of a move are performed with ample spare time before the bag is delayed or kicked. For instance, you might say " abit of meantime there" when referring to a move or you could be more specific and say "there is 1 second of meantime" (The time between the last second last add and delay or between the last add and the kick).
As I said, I am sure there is a well known name for this, I am curious, fill me in.
Oliver Adams
i guess i'm a little foggy on what you're saying. are you saying that if i did a move like a dlo and had a vast amount of time between my dexes and the stall it'd be mean time?
Shredster
Post by Shredster »
Do you mean like an uptime dlo sorta? Like if I were to do a Dlo "SET", then there would be a lot of meantime before my delay?
I can think of uptime swirl. When I do an uptime swirl, there is a ton of time for the delay and it often throws me off for the delay. Is this what you mean by "meantime?"
Chris May
Post by mosher »
I am pretty sure he means the degree of crispyness.
chris, those were the exact same two moves I was going to use for examples in my reply, until I decided not to reply at all.
Hey Ollie!!! I have a bag for you! - Send me an email with your address!!
That's a cool concept - I think I understand. I think a good example is sometimes I hit smear as a bail out of assassin - when I don't quite set high enough - so I try and hit an assassin and the set doesn't come up as high as I wanted - so I skip the duck and just hit a mirage out instead - so I have like a chest high pixie set - then a big amount of "meantime" before I do the mirage.
Another good example is sailing - especially when I'm trying to hit a fairly hard sailing move - if the set isn't right - I will bail to a toe - so we have an uptime pixie switch or smudge - then heaps of "meantime" before the stall.
When these things happen - I tend to pass it on like I'd "the'd" a move - because I'm bailing from what I wanted to hit - I guess it depends who I'm playing with and how early in the run it is - like if I did a meantime move on the first move - I'd probably just try it again - after all I haven't dropped the bag and I'm still doing genuine guiltless moves - I think it's ok to keep going - but if I did it on the 20th or beyond contact of a run - I'd definitly either pass it on or try a really stupidly hard move to make up for it.
Good work Ollie!
Shredster
Post by Shredster »
Describing a move as:
Stupid hard
Stupidly hard
...Makes me laugh so hard. It just sounds so funny.
I remember andrew grant saying: Fusing butterfly on its own is stupid hard!
And now Jeremy with "...or try a really stupidly hard move..."
I don't know, it just sounds so funny.
Chris May
joplick
Post by joplick »
i think he means how much time you have to delay or kick the bag after you finish all the dexs, spins, etc. on one vid (i think budas best) in the vasek live section he hits something and has a lot of time for the clip delay after dexing the bag downtime.
~Jared Wilbur~
Women are like a fine wine... they get better with age.
[life is]"A cycle of hollow joy and vicious self-hatred."
Neon Genesis Evangelion: The End of Evangelion
Shredster
Post by Shredster »
I like how the author hasn't cleared any of this up for us.
Chris May
Uranos
Post by Uranos »
i think Ollie's idea is great!
keep up the good work in singapore man 8)
Alex Urano
Blue_turnip
yea
joplick interpreted it right.
It is kinda like crispy but just after everything is done.
Did you get my email jeremy? I sent it to your lizardking account
Oliver Adams
RRendsvig
Post by RRendsvig »
If I understood you correctly, then Mads Hole used to advise us younger players to sometime "smoke a joint on the way down" - meaning "relax, there's lots of meantime there!"
Rasmus Rendsvig
