NotHisRealName
PostPosted: Mon Sep 12, 2005 2:30 am Post subject: Symp whirl tips Reply with quote Edit/Delete this post Delete this post View IP address of poster
I noticed there's nothing written on .org about symp whirl.
I seem to be having issues with keeping balanced at the end of the move, and struggle with hitting anything out of it.
Any tips?
_________________
Comment in the BCS blog if you feel the need to.
Gareth Williams
Back to top
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
BalinorNZ
PostPosted: Mon Sep 12, 2005 5:55 am Post subject: Reply with quote Edit/Delete this post Delete this post View IP address of poster
I have a tip:
It is a great idea to post topics reguarding trick tips, in the trick tips forum Very Happy.
Tips reguarding symp whirls I cannot help you with though, i'm sorry.
*Moves Topic*
_________________
Please Challenge Nic Bathgate
Entrys for the March 2006 online competitions are due 31st March! Submit them now to
[email protected]!
Events: Open Sick1, Open Sick3, Novice Sick1, Novice Sick3.
Back to top
View user's profile Send private message Send e-mail Visit poster's website AIM Address MSN Messenger
ICQ Number
NotHisRealName
PostPosted: Mon Sep 12, 2005 6:13 am Post subject: Reply with quote Edit/Delete this post Delete this post View IP address of poster
My bad Embarassed
Too many sections to keep up on.
_________________
Gareth Williams
Back to top
Uranos
PostPosted: Mon Sep 12, 2005 6:21 am Post subject: Reply with quote Edit/Delete this post Delete this post View IP address of poster
Tips for symp whirl:
Practice doing it without the bag, and see how vertical/horizontal your dexes are. If they are a bit of a vertical motion, then you have to train it so that it becomes like slightly horizontal, just like normal whirl.
A good way to practice the above is to stand with your hands on 2 tables, so you can float in the air...and practice it like this.
Other tips:
- Set low, emphasies on lowering your clipper foot when you jump upwards for the dex. The clipper doesnt set the bag up. The Jump does.
- think of dexing forward a little at the start, Although this might be a bit risky, i suggest you should try this using the 2 arms on a table method first.
-Practice and practice clipper set whirls
- bend your knee down before you set for the trick, so you can get all the momemtum.
I remember Matt Cross giving great tips somewhere in this "Trick Tips" section.
Good luck, your symp whirls look clean by the way when i saw one Wink
_________________
Alex Urano
Melbourne Footbag Club
Read my blog here:
http://www.modified.ca/footbag/viewtopic.php?t=11782
Back to top
NotHisRealName
PostPosted: Mon Sep 12, 2005 5:43 pm Post subject: Reply with quote Edit/Delete this post Delete this post View IP address of poster
I'll try to be a little more specific.
I don't 'set' the bag as much as it is set during the start of the dex.
The set is quite low, usually just above the knee, which I think is important for being able to do the dex without having to jump too high to get there.
My Dexes are clean - there's no problem with the motion.
I find I'm usually leaning foreward at the completion of the move, be it from landing the symp, or just my style/form, I'm not sure which.
In most cases I have little or no controll of the bag after, bailing to a sloppy and rushed osis, or toe.
So, in review, the problem is with my balance at the end of the move, and my controll of the bag.
Does anyone have any more tips - things I can keep in mind during my next session?
_________________
Gareth Williams
Back to top
Jimpenske
PostPosted: Mon Sep 12, 2005 7:44 pm Post subject: Reply with quote Edit/Delete this post Delete this post View IP address of poster
I found that it really helps to practice this move on a trampoline. It takes a lot of leg strength. Practicing on a tramp makes it easy to do the motion. You dont need to use a bag just practice the motion. I hope this helps
peace.
Back to top
hacksterbator
Washed-Up Child Star
PostPosted: Mon Sep 12, 2005 10:27 pm Post subject: Reply with quote Edit/Delete this post Delete this post View IP address of poster
Jimpenske wrote:
Wanna see my turtle filp?
_________________
Andrew T. Grant
When I'm hosting Rapcity, you're gonna pay! I'm so Hip-Hop i freestyle my resumé!
Sold Master P's phone number on eBay! I'm so Hip-Hop i freestyle my resumé!
Hip-Hop Weiners (All Beef, No Chicken)
Back to top
ScvCanFly
PostPosted: Fri Sep 30, 2005 12:16 pm Post subject: Reply with quote Edit/Delete this post Delete this post View IP address of poster
what about symposium whirling swirl? any tips?
Back to top
PostPosted: Mon Oct 03, 2005 12:15 pm Post subject: Reply with quote Edit/Delete this post Delete this post View IP address of poster
if balance is your problem, then practice them with an emphasis on balance; i.e., freeze the symp whirl, using your arms/upperbody to stay balanced. Once you can freeze a symp whirl, hit the move and set the bag up while maintaining proper balance. If you miss the stall but attain a balanced position, then you have succeeded. If you hit the stall but cant freeze the whirl and you fall over, you have failed. If you hit the whirl and you attain a balanced position post-whirl, you have succeeded in all aspects of the move.
We all had balance problems on one move or another- clipper for example. So what did you do? You practiced achieving the correct balance/posture for hitting clipper. The same applies here. You need to practice landing symp whirls in a position that allows you to be completely balanced, with your weight evenly distributed.
_________________
From Shredder to Master Stitcher to Sensei, Senor Grommet does it all . . . while maintaining his super-sized ego. Many have asked Grommet, "How DO you do it?" Truthfully, I answer, "I don't know. I guess I'm just really talented."
