another one by Josh Gayhart
http://www.footbag.org/gallery/show/4067
josh sent me this a while ago, but I stepped out of the room and forgot about it for a while. He wanted me to verify it's cleanliness. By the time I came back, he signed on. I saw the move, and flipped out!! I think it's totally clean, and it's a ridiculous trick!!!!! I had to call Josh on the phone and tell him how awesome the move was and give him huge props. He asked me to post it. Hope you like it.
8O 8O 8O
footjoe
Post by footjoe »
Props one this very sweet trick he also sent it to me to verify clean-ness and its deffnetly clean , Josh you are the man!!!!!!!
15 year old Joe Kulacz
Post by HG »
I love you
ebo
Unexplained Bacon
Post by ebo »
this is both ridiculously hard and clean.
GO MASSIVE TRICKS!
RRendsvig
Post by RRendsvig »
Gaddam, that IS hardcore!!!
-- The only concern I have about the cleanness, is wheather or not vertical Illusions are clean - and thus flails etc...
Rasmus Rendsvig
if you think about it, that set is harder than barraging, or symp barraging. with symp barraging, you can kinda just set it behind your leg and jump over it. with this set, the bag has to go in front of him, then he has to jump from front to back... the window is much smaller. So if you think about it, this move is harder than nemesis...
Post by C-Fan »
8O 8O 8O
Damn dude. Clean, nasty. Damn.
Prenz
Post by Prenz »
RRendsvig wrote: -- The only concern I have about the cleanness, is wheather or not vertical Illusions are clean - and thus flails etc...
I'm far from an expert, but I do illusions in this way as well. It is completely clean because the dex is done like a swirl dex... you are "drawing" a horizontal cone with ur shin around the bag. Whereas ATWs/Legovers/Mirages draw vertical cones.
If you notice the illusioning foot is in an "inside catch" type position making it very analogous to a swirl (think of a butterfly swirl, again the swirling leg draws a horizontal cone instead of a vertical one but that is how the trick is done!). This is how we are trying to do the trick, NOT like a legover bailed to opp. toe.
I guess I'm going off on this because someone called my illusions "the" because at the "peak" of the dex my leg is not in front of the bag but rather, above it. It aint 'the', its style. I'm doing it like a non-cross-body swirl dex bailed to opp. toe.
EDIT: I guess it would be more correctly called, a non-cross body REVERSE swirling motion.
Craig Kowal- representin' Ivy League footbag baby. Right...
habitat
Post by habitat »
yeah, kickass josh, you are a madman!
James Randall
xwize
Post by xwize »
huge props josh! 8O
sick sick sick trick
keep 'em comin'
Aron Tennant
Post by mosher »
YES!!!
You're so innovative and awesome!
ted
Post by ted »
Wow, weird. It looks like a symp bubba beater bailed to a butterfly. I bet Pinkus could do it too.
Theodore Anderson
Jorden
Retro Athlete
Post by Jorden »
Oh great. Now there's puke everywhere. I hope you're happy, Josh. :wink:
That shouldn't have happened. It can't happen -- but it did. Mega props!
Jorden Moir
qphox
Bullshit Detector
Post by qphox »
Reiteration: Gross.
Could you do Symp Bubba Atomic set? ie: the first two dexes, but then back to ss Butterfly?
- Kevin R.
F = G*((m1*m2)/r^2)
Know thy enemy.
KronoKicker
Post by KronoKicker »
oh my! thats friggin rediculous. Awesome Josh!
Aric McIntosh
Anz
Anssi Sundberg
Post by Anz »
Props!
Now flipside.
BalinorNZ
Post by BalinorNZ »
I dont know if you can really call that a 'set', but then again alot of the harder sets are near impossible to do as proper 'sets'.
What i mean by 'set' is:
The dex(s) is uptime (not while the bag is peaking or downtime at all)
Your dexing leg plants before the bag begins to fall so that equilibrium can be regained and the second part of the move can be performed well.
Ofcourse there are players around good enough to do almost anything so we end up with examples like this where the set is done almost when the bag peaks and the second part (dod) begins so quickly afterward that the move is possible.
The result generally is that the move is performed sort of 'crammed together', but that cant be helped with a move that is so difficult as this.
Props on that trick Josh, that is absolutly insane :) Makes me wana go try and perfect the bubba set ;)
Ogden 09/04
Post by Ogden 09/04 »
thats insane, that should go on massive trick, crazy, Mega props!!
Could you make a clip of it at normal speed please?
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
Derrick Ogden
ebo
Unexplained Bacon
Post by ebo »
BalinorNZ wrote:The result generally is that the move is performed sort of 'crammed together', but that cant be helped with a move that is so difficult as this.
I disagree. For me, it's not crammed together, but rather done in one
fluid motion. It looks very controlled, and that's what matters. The
barfly wasn't rushed, and ohmygodthismoveissoinsanelycleanandmassive!
qphox
Bullshit Detector
Post by qphox »
I don't think it matters if it's a set. The fact is we're taking the trick, and separating it into two understandable components. Symp Bubba op Double Down.
If you said something like...Alpha Reverse Mofly(I guess), you'd get tons of people saying, "What I don't understand explain this to me!".
The name and trick are clear to understand this way.
- Kevin R.
F = G*((m1*m2)/r^2)
Know thy enemy.
