Removal of first eyelet=more clipper flatness?
Have you noticed?
yes
4
21%
no
6
32%
no
6
32%
I need more clipper flatness; i'll try this mod
3
16%
Total votes: 19
Post by Senor Grommet »
has anyone else noticed that by removing the first eyelet of the rod laver shoe that one's ability to achieve flatter clippers greatly increases??? It does for me anyway.
can't dex
Post by quadgun »
By first eyelet, do you mean the one closest to your toes or your ankle?
brian relly
fan-tas-tic
Post by brian relly »
Yeah, but only because I laced them up normally after I did this, so the top of my foot has more resistance, which flattens out the sole and the whole outside surface more, rather than the lower tongue, or "knuckle" part of your foot, because previously there were no laces there, due to the toe wall lacings.
esteban barnez
myspace.com/rawcakes
david wrote:I was just sitting here surfing and my mom looks over my shoulder. I had to jab down the down key real quick so she wouldn't see that topic title and question me about what kind of site I was going on.
Jdigges
Post by Jdigges »
Aye you talking about leather or mesh?
Post by mosher »
I believe he is talking about the topmost eyelet.
The arc of my broka mod sliced off the first eyelet on my climas. I have done this on my lavers in the same way.
You can feel the tendon/bonething that presses against the shoe, ankle movement is restricted at the point where the shoe presses against that tendon.
This mod helps mostly in the sense of getting your heel down and your toes up, not so much in the rolling over sideways sense, the other part of the broka mod is for that.
And it doesn't matter if it's leather or mesh.
No, I am talking about the lowest eyelet, the eyelet you'd cut off to open up the toe box. When I did this, I could much more easily attain crank by "knuckling" my toes. It helps to create a flatter stalling surface by elevating the toe region in relation to the heel.
peanutbuterboy
Post by peanutbuterboy »
You only cut one off....I cut the bottom two and I dont notice any change in my clippers. I have some of those magic ankles that do what ever I want them too :wink:
Luke Andrews
Post by mosher »
My post still holds.
Post by C-Fan »
Hold still, my post :oops:
ShredOnLawn
Post by ShredOnLawn »
After Modifications on 3 different kinds of shoes and over 12 pair of Lavers I've found the best mods is leaving al the eyelets but cutting off as much of the wings as I can without cutting the eyelet. It helps my Fairy and Pxie but leaves my clipper unchanged.
However, cutting out the inside layer of canvas on the inside surface panel and outside surface panel gives the shoe a tighter more comfortable fit that helps me be able to curl my toes more forcing the inside surface to flatten out more.
I vote no.
Lon Smith
